Old 10-20-2018, 08:57 PM   #3
BirdDog
BirdDog's Avatar
Not repairable. If it was a 4 stalk and the 4th stalk broke (lower left stalk), you could replace that, but the other 3 stalks aren't repairable (or individually replaceable). They are part of that riveted assembly.
While you're replacing it, you might want to think about a 4 stalk switch (to add on-board computer). Forum member Pdwight makes a great harness that makes adding the OBC a snap. (I should say he used to make them, but I think he still does?)
OBC isn't something everyone wants, but if you do, now would be the time to add it!
Also, depending on your model year, the stalks/caps may have a shiny or a flat finish. Just mentioning this in case that matters to you.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
