Old 10-04-2018, 06:54 AM   #2
steved0x
steved0x's Avatar
Reserved post # 2 for step 2 of the procedure when the parts get here
On the product page for these camber plates:
Front Monoball Camber Plate (pr), 996/997/986/987
There are two links:
I don't ever remember seeing that assembly drawing one before, but it contains information that helps with the rebuild process, such as the torque spec for the small screws that secure the retaining cap (45 inch/pounds with blue loctite)
They also seem to show a 2 part spacer for the bottom, where my unit has a single larger spacer for the bottom and a smaller spacer for the top. I don't know if it is because the plates I have are really old or what... Apparently when using these plates on a GT3 you need a smaller spacer on the bottom and so the two part spacer shown in the assembly diagram accommodates that.
I'll finish up this post when the parts get here
