Old 10-01-2018, 12:03 PM   #10
Tyfromoahu
Mahalo I’ll check it out later today. I hope I will get a positive response from my car?!
FWIW: this is not just the Boxster. Every European car I've owned since about model-year '95 has had this "feature". it prevents accidental engagement of the starter to an already-running car. If you stall (or if you turn the key and it doesn't start), you must return the key counter-clockwise to the "OFF" position before turning clockwise to start again.
But there is no "Timer" that counts down before you can start. As others have mentioned: there is an oil gauge that takes some time to read, but doesn't require you wait to start. And, again as others have mentioned: if the motor isn't running, there is no oil pressure. the gauge simply indicates level.
Tyfromoahu is offline   Reply With Quote
