Originally Posted by flouese
I have a 1999 Boxster 2.5L with manual shift. I used DOT 4. I installed the master w/o conducting a bench bleed due to ignorance. I guess I missed or skipped over that step in the 101 Projects book. Is there a graceful recovery or will this necessitate the removal of the master and then doing the bench bleed and re-install?
Hmmm... I'm sorry, I don't know. I bench bleed as a matter of course. I'm not sure you'll be able (even with a power bleeder) to get that primed / bled.
Maybe Monty can help here.
That's almost certainly the issue.
