Old 09-18-2018, 12:31 PM   #10
steved0x
steved0x's Avatar
Originally Posted by njbray View Post
The 22.6mm seems the correct minimum.
I'm gonna change out the whole lot - just can't do it before next week!
Now it's a question of re-using existing still good pads on new discs or all new pads/discs.
22mm is the wear limit, 22.6mm is only a factor if you need to "turn" the rotor, if you are at 22.5mm you still have 25% left (24mm new, 22m wear limit, which is 1mm per side) which is likely tens of thousands of miles remaining.
If you still have good pads, I would say wait
If you want to do your brakes anyway (it is satisfying to do them all and is is not too difficult), I would say go new all around, new pads to go with your new rotors.
Steve
