Old 08-24-2018, 04:33 PM   #13
thstone
Originally Posted by bagpiperse View Post
I don't know where the engine temp sensor is to check it. I did some searching around on the internet, but didn't find anything saying where the sensor is or how to check it.
Pelican Parts Tech Articles - Engine Sensor Replacement
I don't know where the ECU is either, or how to check if it is sending the signal to the relay. Thanks again.
The ECU is in the rear trunk. It mounts to the bulkhead between the trunk and the engine on the drivers side. Remove the lining and you'll see it.
You'll need a wiring diagram so you can find which pin outputs the signal to the SAI relay.
