mechanical operation ok, but not electronics...
fixed the lock, the ears had broken off. had to file down the shoulders of the tab so the key would turn smoothly (interesting design to use that tab as a cam to create friction the more you turn the key). thanks to all for the advice, ideas. i was so pleased about rebuilding the lock, but things after reassembling the door things are not working. it all looks right, the key unlocks the drivers door, but the passenger door does not follow, it does not lock or unlock. just mechanical locking is working. all the wires look connected. any advice?
Also, the windows do work, they move down just that little bit when you pull up the latch, but it seems to me the window is not aligned any more, there seem more gap to the left of raised glass, and even lowered it hits the roof. could diassembling the door have moved the window position?
