Old 08-03-2018, 10:52 AM   #4455
Gilles
Originally Posted by Burg Boxster View Post
The Motive Bleeder works fine either wet or dry and do keep pressure below 20 PSI.
Personally, I prefer dry but either way beats the heck out of finding someone to pump the brake pedal while you bleed / flush.
Good luck
I am not sure how you can bleed the clutch without a Motive Bleeder as the manual calls "pressurize the system and hold the pedal to the floor for 20 seconds..."
and yes, during those 20 seconds you will get at least one of the large break fluid containers flushed through your car.
To avoid the risk of pushing air through the system, I just pour 'two' large containers into the Motive bottle before opening the bleeder at the slave cylinder :-)
