Looking for advise on engine issue please
Hello, I'm seeking more advise. I have a 1998 Boxster and switched the key, immobilizer, computer and ignition in the vehicle from a donor Boxster. I put everything in my car and the dash lights turn on, headlights, windows all work. The car after the first accessory switch in ignition works, but I go to start and nothing!!!!! Could it be a fuse, relay or something. It all started when I purchase the original Boxster without a key. Then I bought the donor kit parts. The vehicle sat for 8 years. I'm trying to make sure the engine turn by the crank shaft bolt. I pulled all plugs out and sprayed the inside of the cylinders with oil. Still waiting to see.
