Hmm? Ideally, the cables should have been in the exact same position with the new shifter as the old. Mine were, no issues with centering tool either. As mentioned, your MM might (probably is) shot if original, but I would guess your overall shift linkage adjustment is out of whack. It may require a full adjustment to include the trans side. Might be worth looking at your cables and see if they are giving it up at the trans. Again, you should have literally been able to drop in the new shifter and not adjusted anything and been fine.
