Old 07-16-2018, 01:55 PM   #1
AZ986S
AZ986S's Avatar
1st hard to engage only sometimes
I recently installed a 997 shifter in my 02 Boxster S.
Although it seemed fine dry testing it before re-installing the center console (never did not go into 1st or any other gear), I occasionally am not able to put it in 1st after being in neutral when engine running. This happens when I'm at a red light, not when cold/hot. I'll sometimes try to rev the engine up to make it engage, but I fin that I just have to try a couple times until it goes into 1st. Not a show stopper, but it has happened at the track when I'm trying to pull out of grid and is somewhat embarrassing
I noticed that when installing the new 997 shifter, that the centering tool was worthless as I did not have enough adjustment on the cable for left/right when I used the tool. I'm assuming my problem has something to do with this. All other gears have not really changed, even after drain/refill with Porsche fluid, and are fine. Do I just need to make an adjustment somewhere else? Seems like the adjustment was bottomed out.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
