Old 06-17-2018, 05:40 AM   #11
KevinH1990
KevinH1990's Avatar
The driver's side has held up well with a small amount of yellowing in the UV coating. As you can see in the attached photo, the passenger side has yellowed significantly. I think I would use the process I followed previously with the exception of the final step. The UV coating seems to have been the weak link. I plan to remove the UV coating from both lights and replace it with something stronger. In this thread: Headlight Restore Jakeru recommends the product I plan to use. I need to purchase a respirator since it appears to be hazardous if you inhale it.
