Old 06-15-2018, 01:51 PM   #15
TiberiusBoxster
Turn the headlights on (to parking light position), then test at the car side connector between common ground and parking light +, just to be 100% sure you have good power between the two (unless you already did that).
Yes, that was the first thing I did. I have power there. I was able to use that to jump the connection and make sure I had power at the bulb. I will remove the socket and try to clean up the ground. Thanks again.
No worries, Starter 😀
2001 Boxster Base
TiberiusBoxster is offline   Reply With Quote
