Old 06-15-2018, 11:59 AM   #14
particlewave
Originally Posted by TiberiusBoxster View Post
I will hopefully get a chance to do that tonight. I don't understand the last part of what you said, what do you mean by run the test light between parking light + and the common ground. Would you mind to explain that a little better?
Thank you everyone for your help.
Turn the headlights on (to parking light position), then test at the car side connector between common ground and parking light +, just to be 100% sure you have good power between the two (unless you already did that).
