Originally Posted by KevinH1990
I've done the "Dennis Vogel Install" and I think Rick's suggested procedure will work.
I recently bought a 2005 Mercedes C230 that had a torn seat cushion. When the upholsterer repaired the cushion, he inadvertently damaged the seat heating element. He replaced it with an aftermarket pad and I wired it into the system in a manner similar to the one suggested by Rick. The Mercedes has 3 heat levels and they all work fine,
You can check this thread on Rennlist for more information on seat upgrades: https://rennlist.com/forums/boxster-and-boxster-s-986-forum/915206-upgrading-two-way-power-seats.html
Unfortunately, the document is too big to post here.
Kevin,
Thank you, I will check it out. Where about do you live in VA?
Thanks,
Chris
