My most recent engine failure went like this...
Losing coolant.
Continued to drive the car.
Replaced coolant tank. Still losing coolant.
Tightened all coolant connections. Still losing coolant.
Coolant system pressure test fail. Still losing coolant.
Compression/leakdown test. Leakdown test fail.
Engine stumbles once and low oil pressure light on intermittently.
Engine back to running fine. Continued to drive car. Low oil pressure light on solid.
Continued to drive car. Engine stopped running. Won't start or run.
Installed replacement engine.
I hope that your situation works out better than mine did.
