Old 09-08-2006, 10:00 AM   #2
bigislandboxster
Do you still get the smell or did your parts investment solve the issue?
I had an actual leak earlier this year that was alleviated by replacing the hose and the clamp. The system was belched and repressurized as well. Even after that, I still will notice a little antifreeze smell from time to time, nothing REAL strong, but I can smell it a bit....No leaking tho, maintains proper engine temperature also. I also hardly ever use the AC either.... I don't know if that has anything to do with it tho. Do you have the updated cap for the reservoir bottle? Any condensation above the cap where the rear trunk lid sits over it?
All my fans are working properly as well, radiators and exhaust.....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
