I get this same phenomenon with my car as well. Especially on warmer days or when I've driven the car for longer distances. I had the reservoir replaced a while back and the hoses, level is fine, no leaks whatsoever. Check under the carpet and board underneath by the reservoir as bmussatti says, but I think this isn't too uncommon.....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
