Old 05-23-2018, 07:37 AM   #1
steved0x
steved0x's Avatar
Hmmmm.... pictures?
I'm told that it's easier to find sticky shoes in a 17, than 18. Anyone confirm or deny? But let's see those pics.... maybe they're my new street wheels? Haha
There are plenty of good sticky tires in 18 and more and wider sizes than are available in 17s. However they do typically cost a little more for some reason, even though in my opinion, there is less rubber in them due to the shorter sidewall.
For example, in 17s you might run:
225/45/17 on the front 17x7 wheel
255/40/17 on the rear 17x8.5 wheel
Stock 18 sizes on these wheels would be:
225/40/18 on the front 18x8 wheel - the 8" wide wheel could support this width better than the 17x7
265/35/18 on the rear 18x9 whee - 10mm more width and the wheel is a half inch wider, about the same support as the 255 on the 17x8.5
But with the 18s you have more choices, could run 235/275 front/back - those sizes may be available in 17 but squeezing that 275 on the back 17x8.5 would be a tight fit
Let me get some pictures. Here is the one I painted to match the Fuchs style:
The others are just like this except they are all black on the faces. The inner barrels are still gray.
Edit 2 - I would definitely consider the paint job on these wheels to be amateur level, looks good at 5 feet but not concourse level...
