Old 05-21-2018, 07:29 PM   #11
particlewave
I'm preparing for a steering wheel swap and read upon the pages somewhere in here to put the ignition in the ON position, then disconnect the battery. Wait ~15 minute for discharge (YMMV). Remove steering wheel... replace. With ignition off, reconnect battery. Start the car and there should be no airbag light.
Is that correct?
Thank you.
Yes, though leaving the ignition on is unnecessary. Just unhook the battery a good 15 minutes before the job and make sure everything is hooked up and put back together before reconnecting battery.
