Old 05-21-2018, 07:32 AM   #4
Burg Boxster
Fuse panel is fine... either use a .25 spade connector on the hot side of an empty switched fuse locations (there are a couple depending on your options) or get an 'add-a-circuit' (also can find in local parts stores (like auto zone).
However, for an even simpler install why not use V1's SAVVY connector which plugs into the OBDII port? It also has a dial to set the speed at which the V1 will chirp once and then go to mute (perfect for shopping centers, construction zones, etc.). I ended up putting a SAVVY in each car they're so convenient... (like I had done w/ the original hard-wire adapter) and then run a cord from SAVVY behind trim to top of windshield. When switching between cars I only need to quickly unplug detector at windshield from one and plug it in on other and I'm rolling again in no time.
Savvy | Valentine One | Radar Detectors
Good luck
"Cool Prius!"
- Nobody
