Old 05-04-2018, 11:57 PM   #15
Geof3
Originally Posted by Finnegan View Post
Approximately how much would an indy shop charge to install a short shift kit? Is the job labor-intensive?
Are you handy at all? It really is a fairly simple procedure. There are plenty of online instruction pdf’s as well. If you want factory, it is a very simple console swap. If you use your existing shifter as a donor it’s a bit more labor but still very doable. Probably the hardest part is just getting the console out and back in! Swapping the shifter is easy.
