Thread: Spacer question
Old 04-10-2018, 08:22 AM   #20
deathsled986
Originally Posted by DWBOX2000 View Post
Does 260 sound right for 4 15mm spacers and lugs?
Any before and after pictures?
I bought 4 15mm spacers with extended lug bolts for $54 shipped off eBay last year. It's just a simple machined plate so it's not really hard to get right (and yes I did get hubcentric ones). $260 is WAY too much for what you're getting. I've had them off and on several times and have been pretty rough on the car including thrashing it on the Tail of the Dragon. The bolts are doing just fine.
Originally Posted by Anker View Post
Spacers will increase camber because if the lengthened lever arm of the suspension, and with the increased camber you also get a change in toe-in. Whether you change them enough to go out of spec is another question.
Untrue. Alignment does not change with spacers just as alignment doesn't change if you install wider wheels and tires.
deathsled986 is offline   Reply With Quote
