Old 09-03-2006, 08:33 AM   #2
KevinH1990
KevinH1990's Avatar
I haven't exactly "been there"; I bought my Boxster in April. Also, we usually have less than 3 snow events a year in Central Virginia so the conditions are generally not as sloppy as you experience. I'm not planning to drive my Boxster in ice and snow, so I'm not purchasing as set of wheels and snow tires.
On the other hand, I found a good deal on a used hardtop so I decided to buy it for winter use. As you said, the hardtop gives you a rear defroster (as would the GAHH top) and it will shield the soft top - especially the rear window from the winter weather. I only paid $610 for my hardtop, so the way I look at it, if I can avoid replacing my soft top, the hardtop will pay for itself. I have a one car garage that my wife uses, so I'm storing the hardtop on a hoist. That option is probably not available to you in an apartment, so you will probably want to consider if you can accomodate a rolling cart. If you need to move the hardtop for storage purposes, you will need someone to help you. It is not that heavy, but it is awkward to handle.
I've heard that Boxsters are relatively good in snow as long as the snow is light enough to permit some ground clearance. I assume that Porsche engineers are familiar with winter weather and would take it into account when designing the car.
KevinH1990 is offline   Reply With Quote
