Old 04-05-2018, 05:23 AM   #1
steved0x
steved0x's Avatar
So, the black padding just pops off. Fasteners hood them on?
Yes, each hoop covering has 3 threaded studs that push into plastic inserts (98658075100) that go into holes in the rollbar hoop. You can pry off the cover using a plastic trim tool to start it and then maybe a big screwdriver for leverage, and then you can unscrew the little plastic pieces from the threaded studs. To replace, place the plastic inserts into the holes in the rollbar hoop, line up the threaded studs from the cover, and give it a whack with your hand to seat them.
