Old 04-04-2018, 08:41 AM   #13
thstone
Originally Posted by rjh986 View Post
I was quoted $800 for the Luk clutch package and 6 hours of labor @ $95/hr. I understand that they are a business but these parts price markups every where are unreal.
While the parts cost is high, the labor rate is on the lower side (for quality Porsche work), so the total, while not cheap, is pretty fair. You're certainly not getting totally ripped off.
Originally Posted by sfkjeld View Post
I’ve been told that if you feel the slightest shuddering when releasing the clutch, you need a flywheel. Certainly was true of mine when I replaced my clutch and IMS at 80k, a few months ago.
Also, as the above post implies, just assume that you'll need to replace the dual mass flywheel. Unfortunately, its stupid expensive.
I don't meant to be Debbie Downer, but you might as well start to get your head around spending over $2K for this job. If by some strange chance that the flywheel doesn't need to be replaced, then consider buying lottery tickets because your luck is hitting big time!
And now you see why many of us DIY the clutch job.
