Old 04-03-2018, 10:02 PM   #3
Geof3
Originally Posted by CaryNC986 View Post
'99 5 spd. So the bolts holding the driver's side driveshaft to the transmission worked their way loose and the driveshaft broke off. My question is on the transmission side of where the driveshaft bolts to. It's the piece with the 6 threaded holes. Can this piece be removed while the transmission is still in the car?
Are the holes intact? Hard to tell in the picture. If they are, and you just need to remove the remains of the bolts, might be easier to just pull the old bolts out. Unless of course, if you are due for new Unicorn blood anyway, then pulling the hub housing might be the better bet.
