Old 04-03-2018, 05:16 PM   #2
911monty
911monty's Avatar
Originally Posted by CaryNC986 View Post
'99 5 spd. So the bolts holding the driver's side driveshaft to the transmission worked their way loose and the driveshaft broke off. My question is on the transmission side of where the driveshaft bolts to. It's the piece with the 6 threaded holes. Can this piece be removed while the transmission is still in the car?
Yes. You will need to drain trans. I would recommend a new seal while ur at it. There is instruction available, but if 2 of the holes opposite each other are still functional then place a flat piece of steel (large screwdriver etc) behind the axle flange to protect the trans and using 2 bolts drive the hub out. There is a steel circlip that will need to be replaced.
This might help. Help identifying Transmission axle flange
