Old 04-01-2018, 02:02 AM   #2
rp17
rp17's Avatar
You can reuse the coolant like you stated. I would drain it all in a clean bucket and use distilled water to check for leaks.. remember to use a new washer on the coolant drain plug. then drain and add the expensive stuff. Bout to do mines here in a couple weeks or so.. keep us updated.. What pump are you using? I'm using a pump from Fcp. Free replacements and sounds good for this application. Pierburg if not mistaken.
Others may add to this. Few threads already...
