Old 03-29-2018, 02:23 AM   #10
JFP in PA
Originally Posted by rexcramer View Post
Inquiring minds want to know. I wonder if anybody has ever pulled the OEM bearing out, pried the inner cover out, cleaned out the old goop and decided that the bearing is fine? Then put it back in?
I read somewhere that some version of a recommended fix is to remove the inner cover of a new bearing. That way fresh oil can regularly get into the bearing. I know it sounds like heresy and who would get that deep into a clutch X/O without a new bearing ready to go, but somebody must have tried it.
If you did, it would promptly fail. The extraction process overly stresses the old balls, races, and cages, which is why LN from the beginning has always said that if you try to install a bearing and get it cocked, and then have to extract it, do no use the bearing, get a new one. The extraction process is a one way trip to the trash can.......
