Old 02-14-2018, 06:21 PM   #2
steved0x
steved0x's Avatar
The rear bump stops are a different part number than the front, it looks like you have 4 of the same part number in your list. I only ever found Porsche rear strut mounts for around $100 each unfortunately, but got Lemforder in the front for much less.
I replaced bump stops, front strut mounts (had visible cracks, but rear did not so I reused them) and struts when I did mine, but reused the rest. My front strut bearings were still smooth and when I gently opened them, they were still good, no dirt in them, so I gently closed them back.up.
Might be a way to save a few bucks if you can reuse some stuff. Good luck with your project!
