Old 02-10-2018, 04:07 PM   #1
Anrho
Help not starting , its not pump or relay
so ... i was a happy driver with a 986 2.5 ... one day it will not start :ah:, checked everything in forums and videos ... pump its working once i jump it from the relay port, i dont know if a new relay with solve the problem, note when i use the tester on the relay socket im not getting ground from one pin ... should i follow the ground to find a short=?? or the relay do some magic to make it work? srry for the broken english hahaha
Anrho is offline   Reply With Quote
