Old 02-09-2018, 12:05 PM   #3
The Radium King
The Radium King's Avatar
there are service intervals for most items (except the water pump, which is a 3 year item):
oil filter
air filter
fuel filter
pollen filter
oil change
brake/clutch fluid flush
transmission fluid change
confirm - power steering fluid level, AC charge
poly rib belt
spark plug tube o-rings
brake pads and rotors (if worn beyond spec)
tires (if worn beyond spec or over a certain age)
smart stuff - treat your cv boots (less work than replacing them) oil pump piston and spring (smart oem upgrade) 2nd gear detent (if a 6-speed)
performance stuff - stainless brake lines, GT3 brake ducts
inspect for leaks/wear - shocks, brakes, suspension components and bushings, rms, cam covers, transmission shift linkage bushing
