When you do the WP/Thermo, do the Oil Cooler 'O' rings while the coolant is out.
The Expansion tank on these will go. So if yours is real yellow, then it a matter of time
Make sure your Coolant Cap ends with 04
Brake Fluid Flush
Drain Trans fluid
Replace oil filter housing
When replacing your plugs, thoroughly inspect your Coil packs for cracks.
Pull Throttle body and Intake tube and clean
That should keep you buisy
Seal Grey
