That is pretty much the classic symptoms of a dirty TB. Even if you don't want to do a complete job of cleaning which involves removing it you can probably get away with a half clean by just removing the intake, throwing some rags under it and going to town with a carb cleaner and toothbrush. Just in case you are not comfortable removing it. The gummy deposits on the butterfly are the likely culprit.
