Old 01-22-2018, 11:53 AM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
Yesterday afternoon it was 70 degrees and partly sunny. Then the thunderstorms came. After nightfall the cold front swept through. I can't complain. I accomplished what I intended to yesterday. By dusk, I had given the engine plenty of turns running the starter, with oiled cylinders and plenty of fresh oil in the case.
Today I am sore and it's a damp, windy 40 degrees outside. Sitting by my wood stove at the computer, it is hard to muster the motivation to crawl under the car. I really need to move it into the garage, but my 2000 S - Audi V8 swap project is filling that space. Wednesday I have a full day off. Then, I'll bolt the rear suspension back on that and switch the cars around.
Today? I think I should turn the engine a little more, then drain the oil. After draining, I'll put fresh oil in with a 50-50 mix of Rotella T6 and some Quicksilver 25W-40 marine oil (as suggested) for the additive package.
Some pictures from yesterday:
6 plugs removed.
Some oil and a very small bit of water came out of cylinder #1 and #3. The others were surprisingly dry.
Taking the cover off after a short rain shower.
The mess in my garage.
