Old 01-21-2018, 11:27 AM   #36
911monty
911monty's Avatar
I just woke up (still on night shift) and read this. I have Fogging oil left over from winterizing my jet skis. I also have about a gallon of marine 2-stroke oil, TC-W3. I'm going to get to work on this, NOW. Today's mission: try to save the engine.
-Thoughts on use of 2-stroke oil?
-Any thoughts on using compressed air in any openings to spread the lube and push out moisture?
I really like Mercury (Quicksilver, Mercruiser) Oils. The 2 stroke oil has a special additive package that is designed as you know to work in high dilution ratios and contain corrosion inhibitors for the top end. Should work well for rings. I'd use the Mercruiser marine engine oil in the crankcase.
Once you pull the plugs I'd get the engine spinning on the starter as soon as possible even if it's cables directly to the starter, much greater agitation to get water out and oil spread around the engine. With no plugs there is no load on the starter so you can spin longer intervals. Drop the pan later, time is critical.
