Thread: Engine Rebuild
Old 01-20-2018, 09:16 AM   #11
jsceash
jsceash's Avatar
As you can see in my Bio I've rebuilt one on my own as well. Search the internet for a Shop manual for a 99-03 this will give you a good step by step instructions. The You tube videos help put perspective you don't get from the manual.
I would take it apart and look at the block and heads carefully depending on your level of damage this can be cost prohibitive. You will need a couple sets of special tools to reassemble the engine. I believe the tools cost about $800 to $1000. Then add $2000 in gaskets, rings, bolts, ramps and a new IMS bearing kit about $695 - $1395. So your looking at about $4000 to rebuild. Or no work and By a salvage motor same cost some less.
