To install.
1. Remove the 17mm bolt holding the seat belts drop the belt out of the way. make sure the roof motor and cam shell is in the service position.
2. Set the roof down into the the roof well back first. Push it back as far as you can then press the front arms down into position.
3. Align the front hole below the seat belt bolt an install the front bolt with a 13mm ratcheting box end wrench. LEAVE LOOSE
4. Lift and support the roof. Put the hardware on the link arm, rubber spacer, steel flange collar, brass collar and flat head socket bolt bolt fasten either side to the motor arm then repeat for the other arm.
5. Either side wiggle the roof mount until the bolt at the rear can be started. repeat to the other side. LEAVE LOOSE (normally I find I have to press down and forward.)
6. Either side wiggle the roof mount until the bolt at the center can be started. repeat to the other side. LEAVE LOOSE
7. tighten the lower bolts then then lower the roof tight the front bolt.
8. Attach the seat belts again.
