Old 01-06-2018, 11:49 AM   #3
jsceash
jsceash's Avatar
I don't believe it makes a difference 02, 03, 04 should all bolt and mount the same.
the cam shell doesnt need to be removed.
I swap a hard top for soft top about 2 time a season. The system I use is prety easy and simple I can do it in about 30 to 40 minutes.
1. With the roof down 17mm wrench remove the bolts from the for the seatbelts.
2. locate the roof bolt just below the seat belt bolt. 13 mm ratcheting box end remove one each side.
3. Raise roof to the service position.
4. There are two more bolts for the frame each side remove them. 13mm ratcheting box end.
5. there is a 6 mm flathead socket attaching the lift link and the motor arm remove one either sdie then get a hand to support the roof and remove the other one.
6. Lift the front end of the frame clear then the back of the roof and canvas.
