Thread: Remote Start
Old 12-16-2017, 02:13 PM   #3
Meir
1999 base
Meir's Avatar
Originally Posted by EnglishManDan View Post
Thanks Meir, I will send this info to my installer however I don't think this is the exact solution. He was telling me that it was something to do with the ignition, and that some wires were sending a different voltage or ampage (I forget which one), and this unique ignition system is why he couldn't get it to work.
I'm not technical enough to know more than that LOL
You are correct.
On the Boxster gen 3, the ignition switch is CanBus.
According to the PDF I attached, the feed to the ignition and starter, are done at the relay panel (driver side upper kick panel).
I’m sure the PDF will help him to figure it out, but if not, there are a lot of professional installers out there.
Good luck.
