Old 12-09-2017, 11:39 AM   #965
steved0x
steved0x's Avatar
The task I dread the most is replacing the ignition switch. That job looks to be even a bigger PITA since the cage blocks access via the drivers side floor. Its going to be a busy 5 weeks.
I did mine mostly through the headlamp switch and by removing one of the AC tubes under the steering wheel, which may already be removed for you. That might give you some room to make up for the bars.
