BTW - every Porsche in my signature had potentially expensive issues, some of which have occurred.
03 Carrera and 02 Boxster we all know about their weaknesses
944S2 - failed valve springs requiring a top end overhaul, premature water pump failure, timing belt failure - not good on a interference engine
89 Carrera 4 - lack of head gaskets causing leaks, premature failure of the rubber damper on the clutch, complex four drive system prone to expensive failures
78 SC - failing chain tensioners, blown air boxes
Cars aren't perfect, we as enthusiasts are just much more aware especially in the internet age.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
