Old 08-22-2006, 10:26 AM   #1
ohioboxster
ohioboxster's Avatar
update cont....
This is the pic after I taped into the harness, soldered the wires and rewraped.
Now its all wired and reinstalled, looks pretty good huh?
This is where I ran the wires and vacuum line into the engine bay. Dont worry nobody will ever see the holes.
These are the additional fuel injector wires that go to the box in the trunk. I zip tied the out of the way after soldering the connections. The box is all wired ready to go.
This is the fuel regulator that I need to tee into and run a vacuum line into the trunk to the Digi box. As boost increases the box fires the 7th injector.
There, I teed into the vacuum right here.
I still need to tee into the line again for my boost gauge. I will decide where after the gauge gets here and I figure out where to mount it. This final picture is the box behind the carpet. You will never know its there.
2002 TT
ohioboxster is offline   Reply With Quote
