A preemptive strike on the waterpump won't hurt but I don't think that is your issue . I believe your issue is related to the breakdown of the foam insulation on the flapper doors in the heater box in the dash . You can get heat out of the system but generally have to set it to max temp but it will bleed down to luke warm . At least that what mine does .
