Old 11-16-2017, 09:54 PM   #2
KRAM36
Need For Speed
KRAM36's Avatar
Originally Posted by Steelepuls View Post
My car did the same thing with the horn, there is a ground on the steering wheel under the airbag that was broken, the sheathing was intact but the wire underneath was broken. Undo the battery, wait a while and remove the airbag. There is a female ground connector on the steering wheel, check if it is still intact. I reconnected the ground with a new connector. Works fine now.
Looks like I'll be pulling the steering wheel. Thanks for the info.
Did you have to pull the clock spring?
2003 Boxster S
