Old 11-16-2017, 09:28 AM   #6
jayspeed999
Originally Posted by 77'911s View Post
Loose steering, check tie rod assemblies. The inner's on these cars have a tendency to go early. You should not be feeling vibrations, check your motor and trans mounts. If they have not been done, change them out. The originals were not very good from the factory.
regards
Also check your front strut mounts. Mine were worn badly and when replaced, my steering tightened up a bit.
jayspeed999 is offline   Reply With Quote
