Old 11-13-2017, 11:57 PM   #13
That986
Everything appeared normal, and dry. I drove about 8 miles with the front engine cover off. No smell of coolant. Returned to the driveway... no weeping... no smell.
Now... I put in 1.5 gallons of distilled. Is that going to be OK? Should I purchase some pink... raise the rear end... pull the cap... slight revs... move that existing... and add coolant if the level drops?
Thank you.
Put it this way I had the exact same symptoms as you for about a week or so, then steam came out of the side vents followed by a large gushing of water.
As for the distilled it's fine in the emergency but not really for keeping in there.
That986 is offline   Reply With Quote
