Old 11-10-2017, 03:03 PM   #934
thstone
While I was replacing the oil sump, I noticed a small drip from the right front area. Thought it might be a very small coolant leak where the coolant hose connects to the radiator. But it wasn't coolant, it was oil.
Removed the right front wheel and found this - the right front shock is leaking oil! In fairness, this was a used shock that was installed after the incident in February. Obviously, it was near the end of its life. No worry, I bought a slightly used replacement PSS9 today and will install over the weekend.
