Old 10-31-2017, 06:14 PM   #7
Gelbster
An essential tool imho to buy when you do an AOS R&R is a Digital Manometer. Check out Pyle on Amazon . They are cheap and easy to use from the driver's seat.
Just test the old unit, then the new one.If in future you suspect AOS failure a quick, easy test gives a definitive,easy to read result that you can share here.
I had what I thought was a marginal AOS, replaced it and thought it was a dud. The Manometer test indicated it was good. The real cause of the dense smoke when cold was a leaking injector that was gradually deteriorating ! If I had let it get hotter, the next stage would have been flames !
That was a good example of the value of a $20 ,dedicated diagnostic tool and some helpful tech advice from Renntech.
